Modelling thermosyphon in Star-CCM+
Old   June 7, 2018, 05:25
Default Modelling thermosyphon in Star-CCM+
HHK
HHK's Avatar
HARIHARAN K
HHK is on a distinguished road
Hi all,
I am trying to model a thermosyphon (which is a heat transfer device based on evaporation and condensation processes) using Star-CCM+. The details were taken from this publication
https://www.researchgate.net/publica...d_thermosyphon
I have attached the mesh I have used and the screen shots of models in Star.
The problem I am facing is, phase change does not happen even after 40 seconds of run.
Anybody who has experience on this, please do comment.
I have seen similar threads in the forum but none of them are properly answered.
Thanks in advance.
HHK is offline   Reply With Quote
Old   June 10, 2018, 07:23
HHK
HHK's Avatar
HARIHARAN K
Hi all,
Does anybody know how to model it?
Please post your comments.
Old   October 29, 2018, 19:13
me3840 is on a distinguished road
Heat pipes are very difficult to model explicitly like this.
You say phase change does not occur, this implies there isn't enough heat to generate the change. Does your model show that the temperature and pressure are sufficient to make a phase change?
me3840 is offline   Reply With Quote
Old   October 29, 2018, 20:38
HHK
HHK's Avatar
HARIHARAN K
Hi me3840,
Thank you so much for replying!
I believe so because all the values I have kept are from literature which includes CFD (in Fluent) and experiments.
It would be a great help if you can tell me why it usually happens and provide some suggestions.
Old   October 30, 2018, 10:31
Merely saying "I applied everything from literature, it should work!" is not a good troubleshooting step :P
You need to look in your model and see if it's generating the thermodynamic conditions for phase change to occur. If it is not, then you may have a problem with the boundary conditions, as those are the only sources of heat. If it is, then there's a problem with how the phase change models are being applied or their inputs are incorrect.
Old   October 31, 2018, 05:26
HHK
HHK's Avatar
HARIHARAN K
Thanks me3840,
I will definitely try to debug in this way.
Will update the thread soon.
condensation, evaporation, phase change, star ccm+, volume of fluid
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
error in star ccm maurizio Siemens 3 October 16, 2007 06:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
