Invisible body
Old   May 30, 2018, 13:25
Default Invisible body
joji is on a distinguished road
I am quite new to the program and attempting the backwards facing step tutorial. after making the step geometry itself , I made a sketch and extrusion(volume) for mesh refinement however i dont see this separately in the body tree. When I click on the step geometry body name, both the backward step and the new volume are highlighted.
I tried naming the step beforehand and then making the part but the same problem occurs. I also tried changing the extrusion method from up to face to blind. I dont see what else I can do.
How do I make these 2 into separate bodies so I use this volume further down the line. Assistance with this would be humbly appreciated.
joji is offline   Reply With Quote
Old   May 30, 2018, 16:30
Matt
fluid23 is on a distinguished road
I don't use 3D cad a lot, but I believe your extrusions merge by default. Edit your second extrusion and change the interaction from merge to imprint... I think.
fluid23 is offline   Reply With Quote
3-d cad models, bodies
6dof model - floating body flinde FLUENT 13 March 6, 2021 15:32
Propulsion of solid body in two phases Nautiker87 OpenFOAM Pre-Processing 0 September 29, 2017 07:45
Two Way FSI of Highly Flexible Body Sunny Chitti Structural Mechanics 0 June 27, 2017 15:22
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body mo_na OpenFOAM Meshing & Mesh Conversion 3 July 26, 2016 05:51
[Need some advise] Am I doing right?? Simulating a rotational mixer setasena STAR-CCM+ 4 March 10, 2013 11:32
