Help with warning "Computation of MultiComponent Boiling Temperature..." |
May 23, 2018, 05:44 |
Rep Power: 9 |
Hello together,
does anyone know what setting I need to change, that the below warning is fixed? Warning: Computation of "MultiComponent Boiling Temperature" has been aborted in 10515 cells as saturation pressure does not increase monotonically with temperature. This indicates that critical temperature is reached. I'm using the following models and think its either the Fluid Film and/or the Multiphase Interaction model:
Greetings, tisa Last edited by tisa; May 23, 2018 at 05:45. Reason: fixing |
May 24, 2018, 04:07 |
Rep Power: 9 |
Hello together,
I found the solution myself. I got some settings of my materials in the film model wrong. After correcting those, everything was fine. Greetings, tisa |
November 29, 2018, 05:54 |
Khilz
Rep Power: 8 |
Could you please let me know what settings did you change to fix this warning?
I am having the same problem with my simulation. |
December 3, 2018, 06:14 |
Rep Power: 9 |
The polynomials of the materials were set to °C (because of my preferred unit), but the numbers of those polynomials were meant for K. So i changed °C -> K and everything was fine.
December 3, 2018, 21:44 |
Khilz
Rep Power: 8 |
Thank you for letting me know.
I have also found the solution to my problem. For others' reference, I have changed the default value of the saturation pressure for the film phase. I used the Antoine Equation with the correct coefficients (not the default) for my fluid and flow conditions. |
boiling, multicomponent, temperature, warning |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 11:05 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[swak4Foam] installing funkySetFields | prapanj | OpenFOAM Community Contributions | 65 | October 8, 2015 18:46 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
