Mass flow rate with rotational Periodicity at Inlet |
May 15, 2018, 01:32 |
Rep Power: 13 |
I need to specify mass flow rate at inlet and I have a sector 30 degree sector with rotational periodicity instead of full. So on the sector model I need to specify full mass flow rate or mass flow /12, in starCCM+. Thnaks |
May 30, 2018, 07:56 |
This question is not clear. Try to explain it with some diagram. From what I get, you can create a selection as a sector for BC but as you say it is rotational, you may able to write some field function for flow rate based on position vector.
May 30, 2018, 16:33 |
Matt
Rep Power: 18 |
I think he is just asking if he needs his to set mass flow to reflect the sector he is modeling or if he needs to define the full annulus value... but yes, the question is not clear.
boundary condition, mass flow bc, periodic conditions, star ccm+ |
Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 4, 2016 00:08 |
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 08:26 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 18:57 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 14:11 |
Mass Flow Inlet | Pravir Kumar Rai | FLUENT | 0 | February 19, 2003 15:03 |
