Helical pipe flow not converging
Old   May 8, 2018, 14:00
Default Helical pipe flow not converging
anon
MisterTummy is on a distinguished road
Hi there,
I have two simulations of a pipe with a junction at an angle. Both the simulations have exactly the same parameters, the only thing that varies is the geometry (one of them has both pipes straight, the other has a pipe with a helical shape). I have solved a steady solution and both converged to a reasonable amount. However, once I run an implicit unsteady solver, only the straight pipe sim converges, the other diverges.
I have no idea why they won't both converge.
Parameters are:
- base size 0.02m
- implicit unsteady timestep: 0.01s
- Re = 800
- Laminar solver
- Segregated flow solver
- Constant density
Inlet is a velocity profile at the left and a negative velocity profile on the right, and a pressure outlet on the top.
Thanks for your help
MisterTummy is offline   Reply With Quote
Old   May 8, 2018, 15:23
Matt
fluid23 is on a distinguished road
Show a plot of your residuals for your diverging transient case.
fluid23 is offline   Reply With Quote
Old   May 8, 2018, 16:23
Default I've solved it
anon
Thanks for offering help though
convergence failure, helical pipe, pipe juction, unsteady
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Setting boundary conditions for simple pipe flow with flow direction changing in time Sipher FLUENT 1 May 4, 2015 21:05
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 22:25
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
Pipe Flow Saima CFX 1 January 10, 2011 17:41
