April 30, 2018, 22:12 |
Mesh Extrusion + Porous Block Extrusion
Mark
Hi all,
New to CFD modelling. This might be very basic. What I'm trying to do is add a porous cylinder block at the outlets of my geometry. However I'd also like to do a mesh extrusion as well to allow the velocity profile to fully develop at the outlet of my geometry. So what I'm wanting to have is: Geometry that I'm working with + mesh extrusion + porous block The only way I can think of adding this porous block is by extruding from the outlet as a separate region and defining it as a porous region. However if I do that, it removes the mesh extrusion I already created ... So it seems like you cannot extrude from the outlet twice? How do I go about achieving the mesh extrusion AND porous block extrusion at the outlet? Thanks. |
May 1, 2018, 12:44 |
Matt
Rep Power: 18 |
If you can't extrude twice then its probably easiest to create a CAD part or a shape and create your regions and interfaces from that.
I also question the validity of placing a porous region at your outlet. You may need an extrusion off of that to get your flow fully developed at your boundary. |
May 1, 2018, 20:19 |
Mark
Hi Matt,
Thanks for your response! Yep, I’ve just been extending the outlet faces on the actual geometry itself using the surface repair tool. I’ll just extrude the porous blocks from the faces of the new geometry, extrude as a new region, and assign it the porous media physics model. Thanks. |
extrude mesh, extrusion, mesh, porous media, porous region |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
Mesh interfaces and reactions in porous media - why not working? | RossFS | FLUENT | 0 | December 15, 2013 06:40 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
