April 22, 2018, 11:34 |
Transition point prediction in Star CCM
Rishabh Kumar
Rep Power: 9 |
I'm using Star CCM+ 12.02 for stimulating incompressible flow over an axisymmetric body.
i need help regarding the following: how to know the transition point over the body and How can I see which part of the body is experiencing a laminar flow please LMK if any additional information is needed. thank you so much for your time! |
April 23, 2018, 10:52 |
Matt
Rep Power: 18 |
Technically speaking, a transition point is a numerical construct that you impose on an analysis. Natural transition is not an instantaneous phenomenon but rather a process that happens over a region. You can determine the approximate location by looking at shear stress along the surface and when it jumps from low-to-high you can assume that the flow has transitioned. However; the when, where and how of this transition is greatly influenced by your model and physics setup. You should try to work some validation cases first so you understand how to get acceptable results that can be verified before trying to model something more complex.
April 30, 2018, 23:59 |
Lucky
Rep Power: 66 |
The wall shear stress check is a good one I think.
Try plotting the ratio of the eddy viscosity to the effective viscosity (laminar + turbulent viscosity). When the ratio is very low then you're laminar, when it's positive then you're more turbulent. If you're using a transitional model, there is an intermittency variable which tells you how much time the flow spends in laminar vs turbulent state. 0 for always laminar, 1 for always turbulent and between 0 and 1 is transitional. |
star ccm |
The transition point | mariochelito | FLUENT | 0 | March 25, 2017 15:36 |
Fluent Vs Star CCM | firda | Main CFD Forum | 3 | February 26, 2011 03:51 |
HOW TO TELL WHERE THE TRANSITION point is? | Rif | Main CFD Forum | 2 | February 24, 2008 09:40 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
Importance of transition point | Tim Franke | Main CFD Forum | 4 | January 28, 2000 12:14 |
