April 20, 2018, 18:37 |
VISCOUS DISSIPATION at the rotating flow
hi guys
I am using Star-CCCM+ to simulate the heat transfer in a rotating pipe. I found the rise of flow temperature is HIGHER at high rotating speed. The input heat is always the same. All the heat are transferred to the flow. But i do not know why the rise of flow temperature is different? They should be always the same. Is that some temperature due to VISCOUS DISSIPATION at the high rotating speed, or more friction loss? Many thanks |
May 1, 2018, 00:07 |
Lucky
Rep Power: 66 |
You can calculate how much the heat is due to the rotation is from the wall shear stress and rotation speed and compare it to the temperature rise that you see.
But what is your thermal wall boundary condition? Is it a fixed heat flux? |
May 4, 2018, 14:44 |
#3 | |
I set the constant power(500 w) in the main body, and the external surface of the shaft is modeled as an adiabatic boundary condition. On this basis, all the heat is dissipated to the coolant through a forced convection between the shaft’s internal surface and the fluid. My prediction is that the flow temperature rise should be same. But i found that the higher speed, the higher rise of temperature .My curiosity is that where is the extra loss? Is it from the wall shear stress? or in another word, from the wall friction losses? Can CFD calculate it ? where to see it. Or the extra temperature rise is due to my model fault. Cheers Gary |
frictional viscosity, rotating fluids, temparature, viscous dissipation |
set different viscous resistance simulating flow through an anisotropic porous medium | m_chiara_palu | FLUENT | 0 | January 5, 2016 11:11 |
Rotating wall velocity boundary condition for axisymmetric flow problem | diwakaranant | SU2 | 1 | March 24, 2013 00:45 |
Newbie to compressible, viscous flow. Advice on approach to problem? | bzz77 | Main CFD Forum | 4 | December 4, 2012 08:59 |
Reverse Flow at Rotating Pipe Outlet | vismech | STAR-CCM+ | 1 | August 11, 2009 11:38 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
