Locating maximum value
Old   April 19, 2018, 03:13
Lightbulb Locating maximum value
Abhishek Makam
abhishek2492 is on a distinguished road
Is there a way to monitor the location of a maximum value, say maximum pressure on a boundary??
Specifically, I am working on a fuel tank sloshing VOF model and I am trying to locate the cells experiencing maximum pressure.
My idea was to create a FF to mark each cell with a threshold pressure value (eg. 1 for above threshold pressure and 0 for others) and the filter them using a threshold derived part. However, I am unable to implement this as I am new to CCM+ and to CFD itself.
Anyone has any idea how to go about this ??
It would be great to know if there is a way to visualise the location also.
abhishek2492 is offline   Reply With Quote
Old   April 19, 2018, 11:32
acalado's Avatar
André
acalado is on a distinguished road
That threshold approach you describe seams feasible. Just search for tutorials using the field functions, it is quite easy to apply them. After you have this defined you can plot using that field function and you will see the highlighted volumes.
Sapere aude!
acalado is offline   Reply With Quote
Old   April 20, 2018, 02:34
Abhishek Makam
Perfect. I did a little more digging and understood that scalar scene plotting a field with threshold works. However, this works for an entire region and not on specific boundaries. I have 6 faces on the tank which are in 6 different boundaries. I wanted to know the maximum pressure and its location on each wall. I am trying to solve this. Any help would be appreciated.
Old   April 20, 2018, 11:03
acalado's Avatar
André
Can't you simply use scalar scenes and choose the boundaries?
Or you can use field function to limit the search within a small distance from that boundary (i.e. use a range of x, y, z values)
Sapere aude!
Old   April 22, 2018, 10:39
Ping
ping is on a distinguished road
you make the input part into each threshold just the required boundary rather that the whole domain
ping is offline   Reply With Quote
locate, maximum
Dynamic mesh udf for oscillating wall QBeast Fluent UDF and Scheme Programming 3 December 17, 2020 03:03
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
Maximum of disturbance for function of y=rctan(x) largeBILL Main CFD Forum 1 December 6, 2008 20:09
Vertex maximum or Facet maximum??/ Hassan FLUENT 0 January 17, 2008 13:44
