Part Geometry is being Changed by Volume Meshing
Old   April 15, 2018, 17:49
Default Part Geometry is being Changed by Volume Meshing
Trey
Bevo2020 is on a distinguished road
I am trying to run a volume mesh on a certain geometry part, so I established a domain around the part however if the wheel is too close to the ground of the domain, the part geometry itself is changed by the ground coming up to meet the wheel. As shown in the attached screenshots, there is no issue before the mesh however once I mesh it this problem arises.
I have attempted to fix this by making my mesh finer and increasing the total cell number as well as using a surface wrapper but this problem seems to persist. I would be really grateful for any advice as I'm rather new to this program and have been frustrated with this problem.
Bevo2020 is offline   Reply With Quote
Old   April 16, 2018, 04:39
tisa is on a distinguished road
You should really try the Meshing Tutorials. The solution to this exact problem is shown there...
tisa is offline   Reply With Quote
Old   April 17, 2018, 03:47
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Use proximity controls or contact prevention in surface wrapper.
Refer this section of user guide.
Pre-Processing > Meshing > Surface Meshers > Surface Wrapper > Contact Prevention.
Hope this helps.
ashokac7 is offline   Reply With Quote
geometry repair, volume meshing
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[Gmsh] 3D coil mesh: can't create the volume? RomainBou OpenFOAM Meshing & Mesh Conversion 3 July 18, 2016 06:09
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 05:22
