SST K-Omega Cubic constitutional relation
Old   April 11, 2018, 18:05
Unhappy SST K-Omega Cubic constitutional relation
Petr Šamša
samsakcz is on a distinguished road
Hi everyone, I have problem with Cubic constitutional relation when I do assymetric plane diffuser steady state sim. When I do the analysis with 'classical' SST K-Omega model (Linear relation) it converges fine, but when I change Linear constitutional relation with the Cubic one it starts diverge after few iterarions (with no dependence on the size or type of elemnts or the number of prism layers).
I use Star-CCM+ v12.02 with analysis saved here. That file is only one of 54 (different type or size of elemnts and different n° of prism layers) variants but all of them diverge at about 20th iteration.
Thank you very much for your advices.
samsakcz is offline   Reply With Quote
Old   April 11, 2018, 22:26
Ping
ping is on a distinguished road
more advanced turbulence and other physics settings will sometimes do this and you have several ways to improve things
.run a more basic setting - eg standard k-w for 100-200 iterations then change to the required and continue solving
.ramp up the under relaxation factors or cfl number over 50 to 100 iterations
.start in first order then change up after a while
.etc
ping is offline   Reply With Quote
diffuser, earsm, sst k-omega, starccm, steady
overshooting of Omega in SST komega using simpleFoam cm_jubayer OpenFOAM 2 June 7, 2020 13:52
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? JuPa CFX 0 December 22, 2015 07:44
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 14:06
Boundary Conditions for k omega SST dancfd OpenFOAM Pre-Processing 0 June 10, 2011 00:25
Wall function implementation K Omega SSt cbarry OpenFOAM 3 August 18, 2009 11:09
