Maximum value of monitored report value
Old   April 9, 2018, 14:38
Default Maximum value of monitored report value
Justin Wiegmann
SirIsaac90 is on a distinguished road
Dear all,
Maybe the answer to my question is relatively easy.
Is it possible to monitor the maximum value of a monitored report value?
If so, what is the procedure to obtain that?
Example:
If a monitored value increases linearly --> maximum value increases exactly like the monitored value.
If the monitored value decreases then --> maximum value should be constant with the highest value from the increasing passage.
Afterwards I want to compare the highest value with the actual value for another user field function.
I would be really happy, if someone can help
Thanks!
Regards,
Justin
SirIsaac90 is offline   Reply With Quote
Old   April 10, 2018, 06:46
Ping
ping is on a distinguished road
create a report of the required type etc called say 'val' - is the report to be monitored
this will create a new system field function called valReport
create another report of type Expression called say 'mval' - is the current maximum of that report and
set the definition to ( $valReport > $mvalReport ) ? $valReport : $mvalReport
might have to do an initiation of mval at iteration zero or one to give it a very low value - eg add another if around the above logic based on iteration number - read the help on field functions since the syntax is the same in an expression report
ping is offline   Reply With Quote
Dynamic mesh udf for oscillating wall QBeast Fluent UDF and Scheme Programming 3 December 17, 2020 03:03
Publish REPORT from a CFD-Post macros rubiconf CFX 0 August 8, 2014 05:58
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
Report > Discrete Phase > Report > How to commands Francesco Micchetti FLUENT 1 January 23, 2008 07:10
