March 19, 2018, 01:11 |
FlatWave Velocity as a function of Thrust
Daniel
Rep Power: 10 |
I'm currently working on a project where I'm simulation the self propulsion of a ship. I'm currently using the virtual disk model as I do have the open water performance curves. In the tutorial provided, it seems that the ship is simulated in a steady flow velocity while you obtain thrust and resistance as the results. You then change the velocity till you get a 0 net force between the thrust and resistance. What I am trying to achieve is to input the thrust or rpm of the virtual disk and get velocity that the ship can travel at. Is there a way to make the flat wave velocity a function of the thrust of the virtual disk or something like that. Any help is appreciated. |
April 10, 2018, 06:01 |
Ping
Rep Power: 20 |
you can but it is not a good idea since the change in inlet velocity creates a wave or depression that takes ages to get level again
the way to do this is to use zero inlet velocity and instead move the hull using a linear moving reference frame and then you just change the velocity in that frames properties as required this method solves faster too and it a great way to run multiple vessel speeds |
April 11, 2018, 20:53 |
#3 | |
Daniel
Rep Power: 10 |
self propulsion, virtual disk model |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
