Flow in gap / Couette Flow with Overset Mesh
Old   March 12, 2018, 16:32
Default Flow in gap / Couette Flow with Overset Mesh
Yannick D'Arino
Yan77 is on a distinguished road
Dear everyone,
i calculated a moving piston inside the cylinder with a small gap using Overset Meshes of Star-CCM+ (compressible flow). I compared the results with theoretic estimations. Without a gap (applying the zero-gap-interface) the pressure and temperature rise is correct. However as soon as a gap allows backflow unrealistic high velocities occur in the gap (>Ma=1) and the pressure and temperature rise is much too small. To get a closer look on the flow in the gap I tried calculating the couette flow with Overset Meshes between two cylinders and two cubics (one fixed one moving). The shear stress is not transmitted (not constant) between the walls and the velocity profile is far away from the (linear) analytical solution. It seems like there is a wrong wall treatment/friction. Has someone experiences with this problem?
Thanks a lot
Yan77 is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
