RKE
Rep Power: 13 ![]() |
When trying to create a volume mesh of a model of a stirred tank (after successfully creating a surface mesh of it), the process fails and the following error message appears:
"Attempt to access global communicator in serial" Is this a problem with my model parts, or my model setup? Thank you |
Rep Power: 24 ![]() |
This is probably not the complete error, post all of it.
Steve
Rep Power: 8 ![]() |
you should explain more detail information..
meshing 3d |
[OpenFOAM] could not open file .vtk in paraview | ali_atrian | ParaView | 8 | August 27, 2014 10:31 |
[OpenFOAM] Saving ParaFoam views and case | sail | ParaView | 9 | November 25, 2011 15:46 |
Problem with paraFoam | ata | OpenFOAM | 14 | November 30, 2009 04:23 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
[OpenFOAM] Xwindows crash with paraview save | srinath | ParaView | 1 | October 15, 2008 09:37 |
