March 12, 2018, 04:58 |
Converting 3D to 2D
Rep Power: 9 |
I have a cylinder with its axis along the Z-Plane. The cylinder was constructed by creating a circle on the x,y plane and extruding it along positive z-axis
After meshing, when I try to covert the cylinder to a 2D problem, i get an error stating "No planes found in z=0 direction" What am I doing wrong? |
March 12, 2018, 21:49 |
Rep Power: 25 |
Do you have a face of the cylinder that exists on z=0? The mesher will not cut through cells for you, the end of the cylinder must lie on z=0.
March 13, 2018, 10:33 |
André
Rep Power: 10 |
Wouldn't it be easier to just create a rectangular mesh for the 2D problem (assuming you're cutting a section along the length of cylinder?)
Sapere aude! |
March 15, 2018, 00:49 |
Rep Power: 9 |
3dto2d, noplanesfound |
Fluent converting 'wall' to 'interior' BC for hybrid mesh | DarrenC | FLUENT | 8 | January 3, 2019 07:24 |
Converting multi zone date to ensight error | peterhess | OpenFOAM Post-Processing | 0 | June 4, 2017 22:32 |
[ANSYS Meshing] Converting to Parasolid using FE Modeller, | qwe11rty22 | ANSYS Meshing & Geometry | 1 | September 4, 2016 23:35 |
Creating a volume mesh before converting to 2D mesh? | westb | STAR-CCM+ | 5 | September 29, 2012 14:47 |
[Commercial meshers] problem in converting mesh from fluent | kiran | OpenFOAM Meshing & Mesh Conversion | 1 | November 2, 2010 17:25 |
