How do I create a variable heat flux on a baffle interface?
Old   March 6, 2018, 10:16
Default How do I create a variable heat flux on a baffle interface?
øyvind
oyvindss is on a distinguished road
I'm making a big heat exchanger, 0.86m diameter tubes, 30m high with 5mm thick steel pipes. I simulate the pipes as a baffle interface and I wonder how I can get the correct heat flux over the interface?
oyvindss is offline   Reply With Quote
Old   March 7, 2018, 01:53
me3840 is on a distinguished road
I'm not sure what you're asking. The thread title is:
and you asked:
These are not the same thing.
If you set up the simulation correctly and use appropriate boundary conditions, you should get a similar heat flux to an experiment ("correct").
me3840 is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Doubt - Variable Heat Flux input - UDF Neethu_N FLUENT 1 December 19, 2017 12:48
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
