Hovering Rotor Simulation
Old   February 24, 2018, 19:04
Default Hovering Rotor Simulation
luke sheehan
lukesheehan27 is on a distinguished road
Hi everyone,
I'm trying to run a hovering rotor simulation but I can't seem to make it match the Caradonna and Tung experimental data I want to compare against. The simulated coefficients of pressure are far above the experimental data particularly at X/C 0-0.4. I'm using a rigid body motion method so prescribing a rotation rate to the region containing the blades.
Should I be using a multiphase model in my simulation? I've seen this mentioned in a few papers in order to capture the wake but I'm not sure if its necessary?
Also if anyone knows any papers that take the RBM method and clearly spell out their methodology that would also be appreciated.
Thanks
lukesheehan27 is offline   Reply With Quote
helicopter rotor, rotor blade, star-ccm+
initial and boundary conditions for flapping hovering flight quarkz Main CFD Forum 4 August 30, 2012 14:11
Simulating a moving airfoil in hovering condition quarkz Main CFD Forum 0 November 12, 2010 19:44
Body forces on hovering airfoil sanmysterio Main CFD Forum 1 July 13, 2010 04:14
Efficiency for hovering flight? Zonexo Main CFD Forum 1 April 14, 2008 01:49
Hovering flight and Reynolds no. Zonexo Main CFD Forum 1 March 28, 2008 06:26
