February 9, 2018, 10:21 |
About the heat source option
Rep Power: 9 |
Hello, I am confused with the heat source Option Setting.
So my case is simulating a exothermic reaction. I set a heat sink value according to the reaction enthalpy in the energy source option of the region. (I didn't consider the reaction setting.) But I am confused about the difference between total heat source, specific heat source and volumetric heat source. I think for the same case, total heat source = specifice heat source * mass flow rate * residence time = volumetric heat source * volume. But I got different results after ran those three cases. Could anyone explains me the reason. Thank a lot!! |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
