Modelling for CHT steady simulations
Old   February 8, 2018, 09:04
Default Modelling for CHT steady simulations
Hari Teja Sadhanala
Hari225 is on a distinguished road
I wanted to simulate a cylinder head water jacket(just single cylinder head). Steady state simulations, to check the temperatures on the cylinder head parts after the water jacket simulations.
I have a solid parts and a liquid Region(one solid-liquid inetrface)
i have did simulations by modelling with convection as thermal specifications.but the model is not working.
i have a massflow inlet, pressure oulet.
i have defined the solid parts directly with final temperatures(solid block, combustion chamber head, inlet and exhaust valve rings).
sugesst me about the modelling for the CHT.
thanks in advance.
Hari225 is offline   Reply With Quote
Old   February 8, 2018, 19:15
me3840 is on a distinguished road
Do you have a question?
me3840 is offline   Reply With Quote
Old   February 9, 2018, 04:00
Hari Teja Sadhanala
My question is shall i use Heat flux instead of convection in thermal specifications to model the solid Region.?
Old   February 9, 2018, 10:41
cen
cen is on a distinguished road
what i understood is you have two regions (solid and liquid) then the thermal specification of the interface should be set to conjugate heat transfer, and the thermal specifaction of boundary will be inactive.
cen is offline   Reply With Quote
Old   February 10, 2018, 11:10
If you have a solid region then the interface between the fluid/solid needs no special boundary condition.
As for heat input into the solid (if it doesn't come from the fluid), that's up to you and your application. Nobody can tell you if heat flux or convection is a better model of your physical system.
Old   April 16, 2018, 07:02
Hari Teja Sadhanala
Thanks for the reply.
cht modelling, cht solid properties, cylinderhead, water cooling
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
steady state turbulence modelling?? neprendo FLUENT 1 April 3, 2014 05:27
is it possible to predict how long it takes to reach steady state solution in unstead Alimohamadi_nasr CFX 4 November 11, 2013 07:11
CFL number in steady simulations Rol Main CFD Forum 4 August 20, 2010 10:17
transient phenomenon using steady state simulations beguxa FLUENT 2 April 15, 2010 03:22
