February 1, 2018, 08:46 |
two questions for starccm+
Fan
hello everybody,
i have two questions for starccm+: i want to make a XY-plot and the X-axis is length of the streamline. Which function can i use? Can i show a determinate value on a scalar scense, not the rang value? Thanks for your help! |
February 1, 2018, 10:55 |
Matt
Rep Power: 18 |
I think that there is no direct functionality, but you can work around it pretty easily. If you have generated streamlines, these can be exported as STL which you can bring into CAD. From there you can extract coordinates then bring them back in as a table. Then simply setup a field function to integrate along the length to get your 's' values.
On the second question, I am not sure if I understand you completely. Are you trying to show a set of contour lines rather than a filled contour plot? If so, that is just a matter of changing your contour style in the plot settings. |
February 1, 2018, 11:34 |
#3 | |
Alireza
Rep Power: 15 |
To have a single value on the scaler scene, you may change the range of variable you want to show and make the max and min equal to value you want to show. Also you should disable the clip option. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 06:29 |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 09:53 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 15:39 |
[Other] Some perhaps stupid questions about calculix | lynx | OpenFOAM Meshing & Mesh Conversion | 11 | May 17, 2010 07:48 |
