Problem Exporting Residuals Report
Old   January 26, 2018, 04:26
Default Problem Exporting Residuals Report
Nick
poliakon is on a distinguished road
I am working on optimizing the mesh in Star CCM+ by using a mathematical optimizer in MatLab where I have an error function based on the error between simulated lift and drag values vs. experimental as well as the residuals from the simulation. I have a macro that runs the simulation and exports the results into a CSV file.
The problem I am having is that the x,y,z momentum residuals are not being exported to the CSV file and it just says that the value is zero. I'm not sure what I'm doing wrong because I believe that have the reports set up properly in the baseline. Anyone have any ideas of what could be wrong?
(I am sure the macro code is correct because I am getting values for the kinetic energy and dissipation rate residuals)
poliakon is offline   Reply With Quote
mesh, residuals
[ICEM] Problem when exporting face split ecanop ANSYS Meshing & Geometry 1 May 15, 2016 05:28
Acaled Residuals problem vitor.monjardim FLUENT 0 May 16, 2012 16:48
Problem in finding files after exporting optimus_jack031 FLUENT 1 October 12, 2011 03:10
Exporting problem from parallel solvers Kong FLUENT 6 May 4, 2005 12:55
Residuals problem steph FLUENT 5 May 4, 2004 08:48
