Dampers creation with star ccm+
Old   January 21, 2018, 06:17
Question Dampers creation with star ccm+
Timoteo
cfdtbb is on a distinguished road
Hi. I have for example, 3 regions (objects). I able to create between these 3 regions, 2 springs. Is possible create also, 2 dampers between them ? thanks a lot. is very important for me (esqual2002@hotmail.com).
cfdtbb is offline   Reply With Quote
Old   January 22, 2018, 04:10
Question
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Buddy !! You are not clear. can't make anything out from what you have asked. If it important then provide some good inputs.
ashokac7 is offline   Reply With Quote
Old   January 22, 2018, 05:04
Default improving the question
Timoteo
Dear Ashok. Thanks for your answer.
I have a quarter car model, that is: 2 masses (up and down) connected by spring, and the down mass, connected to ground, also by spring. The up mass, produce downforce aerodynamic. This model, I able to create in star, observing the movements between masses and ground. But I need to place also dampers between two masses and down mass and ground. This is my problem. Thanks a lot. Your friend. Thanks again.
Old   January 22, 2018, 06:19
Timoteo
car aerodynamics, damper
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
error in star ccm maurizio Siemens 3 October 16, 2007 06:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
