Importing the surface mesh from IGES file - error code 22 |
January 19, 2018, 11:58 |
Natalia Jablonska
Hi there.
I recently started working on Star-CCM+ at work (and am the only one that has any experience with the software). I was given a 3D model made in AutoCAD in .iges/.igs, but every time I try to import it I get an error, e.g. Parasolid function PK_ENTITY_ask_partition failed. Error token = PK_ERROR_not_an_entity Error code = 22 Severity = mild Argument number = 1 Argument name = entity Entity tag = 4140499 For both "create new part" and "create new region" I tried to change the default settings in the dialogue window, like selecting or deselecting options (I thought maybe command "Create Part Contacts from Coincident Entities" has something to do with it, but it doesn't), but the result is more or less always the same... Unfortunately I do not have access to AutoCAD to try different file extensions. Has anyone had a similar problem with importing the mesh? I cannot seem to find any information about the entities while importing the mesh on user manual. It's only explained in case of remeshing. I would really appreciate any form of help. Thank you. Natalia PS. I am using the software on virtual machine, do you think that might have an impact? (it is not connected to the internet) |
January 19, 2018, 16:43 |
Matt
Rep Power: 18 |
If you cannot import the IGES then the only way to fix it is outside in a CAD software. If you don't have access to one that can be tough. If it is something you can share, I will take a look and see if I can open and convert it.
January 22, 2018, 06:05 |
Natalia Jablonska
Hi fluid23, thank you for your reply. Unfortunately it's all confidential etc. etc. at work. However, I have managed to import the file as 3D-CAD model data - so now I guess I need to create parts/regions, generate surface and volume mesh and hopefully it will work.
entity error, error, iges, import mesh, surface mesh |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 07:47 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 10:07 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
