Can fluent tet mesh be converted into Polyhedral mesh in CCM?
Old   January 7, 2018, 07:57
Question Can fluent tet mesh be converted into Polyhedral mesh in CCM?
Klxing
jealor is on a distinguished road
Hi everybody
I have conducted simulation in FLUENT previously and now I want to simulate in STAR-CCM with Polyhedral mesh.
Since the geometry contains many parts and its tedious if I generate the mesh from the beginning, so I was wondering, if there is a way that I can vonvert the existing FLUENT mesh(.msh file) into Polyhedral mesh in ICEM or in CCM+?
Thank you all very much
jealor is offline   Reply With Quote
Old   January 7, 2018, 10:23
breezeyu
breezeyu is on a distinguished road
Originally Posted by jealor View Post
Hi everybody
CCM mesh can be exported to tecplot(plt) format after that used by fluent,you can try it reverse.
breezeyu is offline   Reply With Quote
Old   January 8, 2018, 01:50
me3840 is on a distinguished road
You can't convert a mesh into a polyhedral mesh using STAR-CCM+.
me3840 is offline   Reply With Quote
Old   January 8, 2018, 02:41
Klxing
What a pity!
Then I have to try other methods.
At least I won't dewell on this idea any more.
Thank you very much!
Old   January 8, 2018, 09:47
Red face
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Import your tet mesh (.msh or .cas) file to CCM. Extract the boundary surfaces from the representation and then create the poly in CCM. Otherwise you can use same tet mesh for the solution also. But converting directly is not possible.
ashokac7 is offline   Reply With Quote
Old   January 8, 2018, 09:53
Klxing
Hi ashokac7,
What you said is right what I have imagined!
So it is possible to extract shell mesh from 3D .msh file and use it to regenerate mesh in CCM? Can you tell me how to conduct the extract operation? Because I have looked through the tabs and did't find any thing.
Old   January 10, 2018, 01:14
Smile
ashokac7's Avatar
Ashok Chaudhari
Hi ashokac7,
Hello, sorry for late reply !!!
First import the .msh to CCM and then go to representation node and right click on volume mesh. You will find extract boundary surfaces node there. Do that. Then extra node will be created below it named as exracted surface. The region name will appear, right click on it and export it (.dbs) . Then import this as surface mesh and you will have the extracted geometry.
Old   January 10, 2018, 06:25
Thumbs up
Klxing
Hi
It worked!
It is exactally what I have imagined to achieve. Can't express my appreciation enough. Thank you so much.
Best Wishes!
ccm, convert mesh, fluent, mesh, polyhedral
[ICEM] Error reading 2D hybrid ICEM mesh into Fluent Kloz ANSYS Meshing & Geometry 1 June 6, 2016 14:45
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? RPjack ANSYS Meshing & Geometry 2 August 27, 2015 10:33
[ICEM] Missing face error from FLUENT even after repairing mesh + other questions unknown159 ANSYS Meshing & Geometry 0 July 5, 2013 21:18
Exporting structured mesh from ICEMCFD to Fluent? jeevan kumar FLUENT 1 January 23, 2012 12:21
