December 28, 2017, 12:36 |
Piston-Rings(Star CCM+)
Rep Power: 9 |
Hello Everyone,
I'm simulation Piston-rings-liner in Software Star CCM+ My Questions are - 1) as my work is Multiphase(Gas and Oil). What is the chemical name of engine oil(5W30). Because I need to select that in the Physical properties of Phases ? 2)is there any way that I can model the oil intake behind the Oil ring using field function at every downstroke of the piston(using Field function) ? Thank you in advance Cheers Hityo |
field functions, multiphase modelling, oil and gas, piston motion, star ccm+ help |
Piston Cylinder with constant pressure applied | shreyansh_rai | FLUENT | 0 | October 6, 2017 10:45 |
Piston Heat Transfer | JPD08 | STAR-CCM+ | 1 | August 19, 2017 05:15 |
one piston dynamic deforming and mesh moving simultaneously | john Lu | FLUENT | 1 | June 20, 2014 08:13 |
Piston Cooling Nozzle Simulation | rajeev50588 | STAR-CCM+ | 1 | February 26, 2013 04:41 |
Piston Simulation | helloworld922 | Autodesk Simulation CFD | 1 | September 9, 2012 23:54 |
