Symmetric mesh
Old   December 26, 2017, 12:53
Default Symmetric mesh
Arun subramanian
arun1994 is on a distinguished road
Hello guys,
Been trying to make a nice hex mesh with StarCCM mesher for a film cooling problem. Although the mesh for the " box" region is quite ok, I am not quite getting a smooth axis symmetric mesh for the pipe/channel . when the tube is at 90 degrees , everything is fine, but when I try to mesh for other angles of the channel, the mesh is really bad/ skewed .
http://turbomachinery.asmedigitalcol...01006_f001.png
How can I overcome this problem?
arun1994 is offline   Reply With Quote
Old   January 2, 2018, 04:03
Smile
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
You can provide co-ordinate system for mesh. But then your overall mesh will be aligned in specified co-ordinate system. Instead what you can do is make inclined pipe as different region and then apply different mesh continuum for it. Create a co-ordinate system with axial direction as z-axis for that pipe and check the mesh alignment option in mesh continuum. Apply new created co-ordinate system to it. I hope this helps.
ashokac7 is offline   Reply With Quote
film cooling, heat and mass transfer, mesh, starccm+
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 20:34
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 07:41
[ICEM] Problems with structured mesh in IcemCFD symmetric problem jexposito ANSYS Meshing & Geometry 3 December 19, 2015 06:34
[ICEM] Mesh reflection to obtain perfectly symmetric grid Chipsgrottel ANSYS Meshing & Geometry 10 December 11, 2014 11:22
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
