Using solution of a complete simulation in order to simulate just an extract
Old   December 12, 2017, 13:06
Default Using solution of a complete simulation in order to simulate just an extract
Benni
bench_ is on a distinguished road
Hi everybody,
I need your help. I want to simulate the atomization of oil by pressurized air in minimum quantity lubrication systems. As you can see them as serial connections of flow resistances, you have to simulate the whole channel in order to know what happens at the beginning/nozzle. I did some single phase simulations (air, ideal gas, turbulent) and got very good results about the air flow in the "atomization area". As a next step, I want to create a modell of only this area with a very fine mesh. Then, I want to add the second phase (oil) as a VOF drp and see what happens when the air passes it.
In my first sim (the complete channel), I created a plane at the point where the detail modell shall end and made a report for the pressure (4.8 bar Surface Average). The inlet pressure is 5 bar. When I try to simulate the detail modell, there is a reverse flow and no convergence although the pressure drop is positive. Can anybody help?
bench_ is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Is there any steady state solution for Gear pump simulation? shivasluzz CFX 13 September 7, 2021 02:48
Symmetric vs. complete model solution stability SanFer Main CFD Forum 1 July 18, 2017 11:57
how to simulate a VIV of the cylinder in a fluid domian use rigid body solution? Mal CFX 13 April 14, 2014 14:44
no solution in second order schemes immortality OpenFOAM Running, Solving & CFD 14 May 23, 2013 02:39
