Residual value Oscillations
Old   December 7, 2017, 11:30
Default Residual value Oscillations
Siddhartha Desu
Siddhartha1993 is on a distinguished road
All,
I am simulating a box barge in head waves condition (first order waves) to study the forces, and wave profiles in the wake.
I am simulaiting fixed barge of L=2m, B=1m, T=0.5m in a tank of (L,W,H = 30,30,20). Using first order waves (wavelength= L). I am using wave damping length of 2L from the boundaries. My BC's are Velocity inlet for
Inlet, Bottom, Top , Pressure outlet for Outlet, Symmetry for sides. I am using about 4.8m cells for this condition.
My problem is with the residuals, They are dying down as more physical time passes but the oscillations are not. Is this acceptable? Could anyone suggest what the problems might be?
Happy to provide more info. Thanks in advance!
Siddhartha1993 is offline   Reply With Quote
Old   December 7, 2017, 13:34
acalado's Avatar
André
acalado is on a distinguished road
I believe the residuals may oscillate however they still appear rather high. They should drop 3 to 4 orders of magnitude.
Have you tried reducing the cell size?
Sapere aude!
acalado is offline   Reply With Quote
Old   December 7, 2017, 15:41
Siddhartha Desu
Can you recommend me what the best size for the tank is ?
Right know my tank is 15 times the length of the barge. Thus I am not able to reduce the cell size much (current cell size = 0.07m). If I reduce further I am getting too many cells to compute effectively (about 15m or more cells).
On the other hand when I was working in a reduced tank size (10 times the length of the barge), I am getting so much reflections from the boundaries and the waves are dying down before the simulation is ending.
Old   December 8, 2017, 03:58
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Which mesher are you using? also physics models?
ashokac7 is offline   Reply With Quote
Old   December 8, 2017, 04:10
Siddhartha Desu
Trimmed cell mesher and prsim layer mesher and surface remesher.
Models: Implicit Unsteady, Eulerian Multiphase, K-Epsilon Turbulence, Volume of Fluid (VOF), VOF Waves, Gravity,Cell Quality Remediation.
residuals, vof damping, wave boundary conditions
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 23:13
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
