December 1, 2017, 04:09 |
Swirl and Tumble on Derived parts
Paresh
Rep Power: 9 |
Hello everyone,
I am running a steady state simulation on single cylinder engine and I want to calculate the tumble and swirl on derived parts. Has anyone done this, as I have tried and I am getting really odd values? Thanks in advance. |
December 5, 2017, 07:27 |
Try on cell set
Yes it is proposed under development idea in Steve Portal . But I read somewhere that you can able to get it on cell set. Try that.
December 5, 2017, 08:59 |
Paresh
Rep Power: 9 |
Hi Ashok,
Thank you for replying. I did create a cell set and then also made a threshold of it, but I do not know how can I use this to plot tumble or swirl. Also, I never came across this method before, so could you please tell me more about how I can achieve this? My initial derived part was a constrained plane section which I used as input part on my reports to evaluate expressions but here I cannot use the cell sets as input, but I can indeed use the threshold as input and on using this, it shows no data when I try to run the reports. |
December 6, 2017, 07:30 |
#4 | |
This article is from steve portal for tumble/swirl ratio. The tumble value is defined as the ratio of angular velocity of the solid body vortex to the axial velocity of the piston. The tumble flow is a superposition of a circular and an axial movement in the direction of the piston. In general: Tu=Vt/Va where va| can be described by: Va=mdot/ A*density Under the assumption that vt and r are in the same plane, vt can be described as : Vt=w_vector (cross product) r_vector You need a coordinate system (CS) in the center of the vortex to which the tumble value is related to and the normal vector of the plane mentioned before: Create a field function for vt. vt = dot($$Velocity, unit(cross($$Centroid ("CS") , $$normal vector of the plane))) Next create a mass flow report (MassFlow1Report) to determine the mass flow that enters the domain. Create a field function for va: va = $MassFlow1Report / ($cylinder cross section area * $Density) Last step: Tu = $vt / $va |
December 6, 2017, 07:36 |
Swirl in region
I am also working on a problem involving swirl. I want to give swirl in the domain. But I know how to specify that on boundary not in region. Do you know anything on this?
December 6, 2017, 07:39 |
Paresh
Rep Power: 9 |
Yes, I did come across this link, it is an alternative to the tumble/Swirl report. I tried using the above equation by creating scalar field function vt and va as :
vt=dot($$Velocity, unit(cross($$Centroid ("Laboratory.CartesianCSYS") , $$Normal))) va=${MassFlow1Report}/(${cylinder_area} *${Density}) Here I am transforming my coordinates, and for the mass flow report I use my section plane as input, but when I run the report, it shows error as cannot evaluate velocity or density. The thing is I am not sure how will this work without using any sum reports. |
December 6, 2017, 07:59 |
#7 | |
And I don't understand that why do we need sum report? |
December 6, 2017, 08:13 |
Paresh
Rep Power: 9 |
My coordinate system is well within the cylinder and indeed at half the stroke. Well, when I create the scalar ff(field function) vt, it comprises of the vector velocity. Now, this is just a ff. So when I execute the expression vt/va, it says cannot evaluate ff Velocity and that I assume is because I cannot assign any part to this ff vt.
How exactly are you thinking about this? Maybe I am wrong somewhere. |
December 8, 2017, 08:59 |
#9 | |
December 13, 2017, 03:48 |
#10 |
Paresh
Rep Power: 9 |
December 13, 2017, 04:15 |
#11 |
Sorry Paresh, I found the way around it. I had to create the swirl so what I did is create the cylindrical co-ordinate system at inlet. And apply the flow direction as components. For this only tangential and axial velocity was required. But I was unable to calculate realizable swirl values in region. Instead you can also do the same. Create a plane where you want swirl value. Then crate local cylindrical co-ordinate system at this plane. Calculate X,Y and Z components of velocity (for cylindrical co-ordinate sys) using report. X is radial, Y is Tangential and Z is axial. So swirl will be (Vtangential/Vaxial). I don't know what is accuracy of this. But this should work, may be.
How to calculate swirl number....? | zkhn | FLUENT | 0 | April 26, 2017 17:56 |
Validation of Swirl Number with Tippelmann Method using STAR CCM+ | shantanukale | STAR-CCM+ | 0 | April 4, 2015 03:04 |
Tumble calculation for engine port | vismech1 | Main CFD Forum | 0 | March 11, 2014 06:45 |
Swirl und tumble number | sven82 | OpenFOAM Running, Solving & CFD | 0 | November 11, 2009 12:30 |
Swirl and Tumble Ratios in IC Chamber - Turbulence | Hussam | FLUENT | 0 | March 7, 2009 00:41 |
