Conjugate Heat Transfer - Meshing Problem
Old   November 7, 2017, 05:02
Default Conjugate Heat Transfer - Meshing Problem
Xinxin Zhu
Zhudasch is on a distinguished road
Hi all. I have a Problem by generating conformal mesh between a pipe and the fluid inside in a conjugate heat Transfer problem.
The model is an Input from nastran-file mit 2mm meshing. I used only one pipe as a small model and I generate the Volumen inside using existing surfaces. (First I duplicate the part and then delete the unnecessary surfaces to form the inside volume) Everytime when I apply the same mesh Setting to all regions, which means the 2 regions are Input part in automated mesher, there's always a error message (see Picture below) that a certain part is self intersecting.
What's wrong with the Methode that I used to generate the proper mesh? What is the right way to do so?
Thank you all in advance
Zhudasch is offline   Reply With Quote
Old   November 8, 2017, 11:20
Ping
ping is on a distinguished road
you have not imprinted the two parts to create contacts surfaces which then turn into region interfaces
but i worry when you say you deleted a surface - both parts need to be closed volumes and you can test this by just meshing each on their own - if this works and you have the contacts then you should not get intersecting surfaces unless the imported surfaces do in fact intersect and you can check that in the surface repair tool
ping is offline   Reply With Quote
Conjugate heat transfer boundary conditions problem GregorAlan OpenFOAM Running, Solving & CFD 10 January 31, 2021 13:13
fluent conjugate heat transfer problem eling FLUENT 9 October 21, 2017 11:10
Conjugate heat transfer problem troyker FLUENT 1 March 22, 2014 14:46
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Conjugate heat transfer problem with porous media piko Siemens 1 April 17, 2009 16:41
