Pressure outlet boundary condition
Old   November 6, 2017, 14:39
Default Pressure outlet boundary condition
Miguel
Miguel Parente is on a distinguished road
Hi everyone! I was conducting a combustion simulation with ppdf model, where I have several pressure outlet boundary conditions, where they are actually inlet conditions. My doubt is in the Mixture Fraction Profile of the pressure outlet do I have to put [0,1] to indicate that is air(oxidizer) that is entering? Or by default is oxidizer?
The point is I have monitoring the mass fraction at that specific boundary, and it is correct, however, when I put [0,1] it is still correct, but sometimes I star to have a combustion process in the boundary when it is far away from the burner, and no fuel is present there.
Thanks all
Miguel Parente is offline   Reply With Quote
Old   November 10, 2017, 01:42
me3840 is on a distinguished road
The default may differ depending on the number of species. You must enter in a correct mixture fraction, yes.
I would not advise using the pressure outlet as an inlet. Stagnation inlet is better formulated for this.
If you are having combusion happen where it's physically impossible this suggests your simulation is not converging or has other problems.
me3840 is offline   Reply With Quote
Old   November 10, 2017, 10:56
Miguel
Dear me3840, thanks a lot for your time. Yes I understand that I don't have convergence. In fact when i say that the only entrance is air, I have a non physical solution, in the control volume I have a considerable number of cells in the sum of mass fraction is well below 1. I will follow your advise and see if Stagnation inlet works better in my case. Thanks a lot for the help
combustion, pressure outlet
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Static pressure boundary condition at outlet jennz CFX 4 February 11, 2014 04:29
Radiation interface hinca CFX 15 January 26, 2014 18:11
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
