Interface Between Rotating and Stationary Solids |
November 4, 2017, 18:12 |
Justin Fisher
I am attempting to simulate a disc brake in Star-CCM+. I have a very simple 3D geometry so far with a rotor and pads. This is a solid simulation only. The simulation is transient and I am applying a rotation to the brake rotor. I would like to model heat generated at the brake pads so that it heats the rotor as it turns. I have tried an in-place contact interface, but to do that I must have the pads imprinted on the rotor. When the rotor mesh rotates, the imprinted boundary rotates with it. Thus heat is only passed to the rotor when that imprinted boundary goes past the pads. I tried removing the imprint, but then the volume mesh does not complete successfully due to a connectivity error. I would appreciate any recommendations on how I might be able to achieve this. I have scoured the help information, but haven't found anything that discusses an interface between a moving and stationary part. |
November 8, 2017, 11:35 |
Ping
Rep Power: 20 |
this a rare case when you should not use imprint and also delete contacts in parts
you should separate the two surfaces that are in contact up in 3d-cad or in parts - ie the pad contact surface and the annular disc contact surface - as separate wall boundaries then mesh both parts separately now down in regions manually create the interface between those two surfaces and it will all work fine |
November 9, 2017, 21:31 |
Justin Fisher
Thank you for the recommendation. I will give it a try.
heat transfer, interface, rotation |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
