Surface Faces from imported geometry
Old   October 26, 2017, 20:18
Default Surface Faces from imported geometry
Miguel
Miguel Parente is on a distinguished road
Hi everyone!
I am trying to run a simulation of cooler with forced convection, like the one of the tutorial. However I have a problem when I import the geometry. The CAD is done in SW, and it is basically a solid box with an air entry and out, and inside it is an cooler and it's heat source. When I import the x_t file, star creates three parts as expected, however each only have one surface face, which complicates thing creating the regions and contact interfaces.
Do Someone knows how to get an imported part as the one of the tutorial.
Thanks a lot
MP
Miguel Parente is offline   Reply With Quote
Old   October 28, 2017, 02:22
Ping
ping is on a distinguished road
try doing a basic tutorial on geometry and meshing - there are several ways to split surfaces.
ping is offline   Reply With Quote
Old   November 1, 2017, 21:55
Miguel
Thanks for the reply. I know how to do it, my point was if there is any option of importing the surface to geometry already separated.
Old   November 1, 2017, 22:56
Ping
in all the supported cad formats that can be imported there is a way to rename or identify faces in the original cad before export and those surfaces and names come into star but i dont know the property to change in solidworks but a bit of experimenting should find it
Old   November 1, 2017, 23:49
Miguel
OK, I will check with the CAD options. Thanks a lot for the replies.
imported geometry, surface faces
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 11:49
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[snappyHexMesh] snapEdge - failure Tobi OpenFOAM Meshing & Mesh Conversion 33 March 18, 2014 04:58
[snappyHexMesh] Open surface - geometry imported from solidworks augusto.s.b OpenFOAM Meshing & Mesh Conversion 1 April 25, 2013 00:17
