Input part for automated mesh (2D)
Old   October 20, 2017, 00:58
Default Input part for automated mesh (2D)
Reuben Buehler
ReubenBuehler is on a distinguished road
I am constructing a 2D backward-facing step analysis. The part was created in 3D-CAD. I have created a "badge for 2D meshing" and the input part for this operation is the model domain. However, when I create the operation "automated mesh (2D)" and I go to select an input part the screen is blank and gives me no options to select. Any insight on what the problem might be?
P.S. The part has a surface that is orthogonal to the z-axis, the surface was created in the xy-plane and then extruded in the z-axis direction.
ReubenBuehler is offline   Reply With Quote
Old   October 20, 2017, 04:46
MRI
Marco Riedel
MRI is on a distinguished road
Hi Reuben,
first you have to execute the "badge for 2D meshing" (right click on Geometry --> Operations --> Badge for 2D Meshing | Execute) and if everything works fine you can select your geometry.
MRI is offline   Reply With Quote
Old   October 20, 2017, 14:51
Reuben Buehler
That worked perfectly. Thanks Marco!
Old   November 2, 2018, 07:25
loe
loe is on a distinguished road
Hello, i have the same problem, but after Execute action nothing happens, selection menu is blank even so. What can go wrong?
loe is offline   Reply With Quote
Old   November 2, 2018, 07:58
MRI
Marco Riedel
I also had the problem and was confused that I haven't it one year ago. I could solve it by translating the geometry out of the z-plane , then execute "badge for 2D", translate the geometry back to the z-plane and execute "badge for 2D" again. Then it works for me.
[ICEM] Mirror Mesh | Delete duplicate mesh pythag0ra5 ANSYS Meshing & Geometry 6 November 19, 2013 08:35
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[ICEM] How to mesh part by part? rikio ANSYS Meshing & Geometry 6 February 24, 2010 20:19
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
