Parameter/Geometry sweep study in STAR-CCM+
Old   October 19, 2017, 05:22
Default Parameter/Geometry sweep study in STAR-CCM+
Soroush Kargar
Seervan is on a distinguished road
Hello everyone
How can I run a sweep study in STAR-CCM+? I mean something like sweep studies in let's say, COMSOL multi physics where you can do a sweep on a certain parameter and the software automatically runs all the changes in that parameter and reports the results.
My case is: I wanna do a sweep study on different turbulence models on a certain geometry and second is that I wanna change the drift angles of a ship model while analising drag force and propeller wake. So the question is that how can I adjust the software to change the drift angle automatically and calculate for the reports; Something like what COMSOL does.
My guess is trying with Optimate.
Any help would be appreciated.
Seervan is offline   Reply With Quote
Old   October 28, 2017, 02:50
Ping
ping is on a distinguished road
you should use design manager which does exactly that and is far better and is replacing optimate but i dont think you can vary turbulence models as part of such a parameter scan yet other than including a java macro in the mix
ping is offline   Reply With Quote
Old   October 28, 2017, 15:22
Soroush Kargar
Greetings.
Tnx for the reply. Can u be more specific? Or even address some tutorials which do so?
I rather avoid using java macros as much as possible
Old   October 29, 2017, 03:55
Ping
there are two tutorials to teach you but it is very easy to use
Tutorials > Design Manager > Optimizing a Static Mixer
Tutorials > Design Manager > Design Sweep of a Static Mixer
Old   October 29, 2017, 12:06
Soroush Kargar
Tnx a lot!
I think I know what to do now.
Old   October 30, 2017, 18:05
André Pinto
AndreP is on a distinguished road
I've been through these tutorials, but I don't know if they'll fit my simulation:
Geometry: 2 Simular Cars within a tunel varying their distance
Outputs: Drag (Force), Lift (Force), Roll (Mom), Pitch (Mom), Yaw (Mom)
Variable: Distance between 2 simular bodies (cars)
Could I have some type of Outputs for a range of Distances of the 2 bodies?
AndreP is offline   Reply With Quote
Old   November 1, 2017, 23:06
Ping
very easy using either an exposed parameter in 3d-cad for that distance
or define a parameter in tools then use this to perform a part transform in a mesh operation prior to a unite or subtraction depending on how you have created your cad of each car
problem when imported geometry from 3D CAD to star ccm, TAREK GANAT STAR-CCM+ 1 May 21, 2013 23:15
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
error in star ccm maurizio Siemens 3 October 16, 2007 06:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
