Rep Power: 0 ![]() |
Hi all,
I'm new to the world of CFD and STAR CMM+. I have a hollow pipe with steady flow,defined inlet velocity of 0.1 m/s and pressure outlet, segregated flow. This is my parameters: d =6mm l =300mm density= 1050 kg/m^3 viscosity= 3.5 mPas I would like to determine the entrance length for this pipe. I have already determine it theoretically as 64.8 mm. How can I determine this using a field function? Can I show the exact point where the flow becomes fully developed graphically? Any advice and/or suggestions are welcome. ![]() ![]() |
Matt
Rep Power: 18 ![]() |
You could create a field function to return du/dx at constant radius (assuming u is velocity and x is aligned with the pipe axis). Then you would want to look for a location where that gradient is zero (or reasonably close). You could maybe setup an XY plot and show x vs du/dx for a handful of radial locations and show where they all reach zero.
developing flow, entrance length, field function, new forum, star ccm+ |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 07:56 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 07:49 |
Field FUnction | akshaybagi | STAR-CCM+ | 1 | January 11, 2016 15:57 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
