Circumeferential averaged velocity
Old   September 4, 2017, 06:31
Default Circumeferential averaged velocity
Andrea
afarkas is on a distinguished road
I am doing a simulation for calculating a nominal wake distribution behind a ship model within STAR-CCM+.
I would like to obtain Circumferential Average of velocity for specified radius, i.e. line integral of x velocity component for radii: 0.2R, 0.3R, etc.
The problem is that within line integral report, user must specify a part (or part surface) and I don't know how to select a cells that lie on some radius.
Does anyone know how to calculate a nominal wake distribution? Should i create some derived parts?
Thank you for your help
afarkas is offline   Reply With Quote
Old   September 4, 2017, 08:07
FluentStarter is on a distinguished road
Hi Afarkas,
I would do it like this:
- Create a cylindrical coordinate system where the z-axis corresponds to the axis around which you want to rotate
- Create a plane that is normal to the z-axis
- Create a cylindrical section (attach it only to the plane section you created before!)
- If you take care that you choose the right coordinate system u should see a line after entering a radius
- Now make a surface average on the line
FluentStarter is offline   Reply With Quote
Old   September 4, 2017, 08:35
Smile
Andrea
Thank you for your reply.
It worked.
Best regards
circumeferential value, line integral, nominal wake
How to calculate area averaged velocity on a surface for a post-proccessing utility? lukas.lebo OpenFOAM Programming & Development 1 April 19, 2017 06:41
Time averaged contour velocity plots tarkesdora Main CFD Forum 0 August 25, 2014 01:36
Time averaged velocity in turbulent pipe flow tsero FLUENT 1 November 2, 2012 04:19
how to plot out circumferentially mass averaged axial velocity in a rotor? wildli FLUENT 0 July 17, 2010 16:54
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
