Axisymmetric volume conversions: is pressure affected?
Old   August 24, 2017, 12:25
Post Axisymmetric volume conversions: is pressure affected?
Andrew
2049 is on a distinguished road
Hi, I'm using a 2D axisymmetric model with a mass flow inlet and examining pressure between two different sized pipes. and the guide says that the axisymetric model works by assuming the volume is swept around the axis by 1 radian, and that reported quantities need to be multiplied by 2pi to get the values for the full 360 degrees volume.
So if I have a mass flow for the inlet divided by 2pi for the swept volume of 1 radian, for example 0.2kg/s --> 0.0318 kg/s, does this mean that the reported pressure should be multiplied by 2pi? So 600kpa becomes 3,769.9kpa? It seems a bit too much, I'm not sure how to do this. Or does the conversion not affect pressure? What values are and aren't affected?
Thankyou for your advice.
2049 is offline   Reply With Quote
Old   August 25, 2017, 08:05
Sebastian Engel
bluebase will become famous soon enough
Dear Andrew,
for 2D axisymmetric case only quanities which are dependent from the circumferencial direction need to be converted, such as volume flow and mass flow.
However, hydraulic pressure is a unidirectional quantity of the fluid. It is not changing in a circumferencial direction for an axisymmetric case. On the contrary, the force (in axial direction) on a surface exerted by pressure is dependent by the circumferencial direction.
You might check out the fluid flow formulation for axisymmetric models in the tutorial manual.
Best regards,
Sebastian
bluebase is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
How to use "translation" in solidBodyMotionFunction in OpenFOAM rupesh_w OpenFOAM Running, Solving & CFD 5 August 16, 2016 05:27
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
