Won't open in Linux, netbeans error
Old   August 5, 2017, 06:10
Default Won't open in Linux, netbeans error
Bob Comstock
RCB0B is on a distinguished road
Hello Everyone,
Recently installed star on a supermicro server but when I try to run it in Linux, the loading picture comes up, then I get this error:
"Could not initialize class org.netbeans.core.windows.view.ui.toolbars.DnDSupp ort"
Star still seems to be running in the background after I exit the error message but no window appears.
Any thoughts on how to approach this? This was attempted with 11.04.012 and 11.06.011 both in Debian. I tried 11.04.012 in the latest ubuntu version but same error.
RCB0B is offline   Reply With Quote
Old   August 8, 2017, 11:19
me3840 is on a distinguished road
When this always happened to me it was an installation problem. If you've done this with multiple versions it's probably a Java package issue. I would suggest you try purging all your Java packages and only install the Sun/Oracle one and see how that goes.
me3840 is offline   Reply With Quote
Old   August 8, 2017, 13:52
Bob Comstock
You mean the java packages that came with the OS? (not with star in the JDK folder where star was installed)
Old   August 8, 2017, 20:22
Hopefully if you use the one that STAR installed you shouldn't need other packages, but perhaps it's a good idea to clear everything out and try again.
Old   August 16, 2017, 02:52
Bob Comstock
So I found a solution (for now). I setup centos on the ssd through my laptop, and installed star there. I put the ssd on my server and now it works fine.....
When I have more time I defintiely want to investigate more with purging java and such.
Old   September 19, 2017, 07:22
lailai
withwolf is on a distinguished road
I'm facing the same error. Have you figure out what is the reason? Because I am not able to put SSD or anything on the server, so your solution is not suitable for me……
Best wishes.
withwolf is offline   Reply With Quote
Old   September 23, 2017, 09:04
lailai
Could anyone give some suggestions on solving the error?
Thanks
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
