Simulation of pulsatile flow with harmonic balance |
August 4, 2017, 10:55 |
Rep Power: 13 |
Hi. I tried to simulate a turbine rotor with harmonic balance module with the following setup.
1) single rotor blade passage 2) Specifying the time-varying inlet total pressure and temperature with field function defined by extrapolating table data. In the stagnation inlet option, I enable the time-varying option and set the frequency. However, I do not know exactlyhow should I calculate the frequency f. Is it just f=1/Tpulse rad/s? 3) constant static pressure=0 at the outlet. 4) Use reference frame to model the rotor rotation. 5) Use grid-sequencing initialisation of a steady RANS solution as initial condition to harmonic balance. With the above setup, my residual drops a bit initially and then it remain almost constant, and at some point floating point error occurs, which indicate divergence. I wonder whether the problem is caused by wrong setup (as described above) or my initial condition is not appropriate for pulsatile flow. I would very much appreciate if some experience people can advise on this. Thank you in advance. |
parametric study in flow simulation | topaz | FloEFD, FloWorks & FloTHERM | 1 | July 13, 2015 08:50 |
how to get a time-accurate solution in Flow Simulation | drdet | FloEFD, FloWorks & FloTHERM | 4 | January 20, 2015 07:11 |
Comparison between Solidworks Flow Simulation and Ansys Fluent | Bruce828 | Main CFD Forum | 5 | February 23, 2013 10:13 |
Unsteady simulation of flow past wheel | Tom | FLUENT | 8 | January 18, 2006 10:54 |
simulation on pulsatile flow in elastic conduit | pratyush rai | CFX | 1 | January 14, 2006 09:10 |
