Detailed Tessellation Parameters
Old   July 31, 2017, 14:33
Default Detailed Tessellation Parameters
Oscar Eduardo Alcocer Escamilla
o.alcocer is on a distinguished road
Hi everyone!
I want to know about the following parameters and how it affects in the geometry:
1. Curve Chord Tolerance
2. Curve Chord Angle
3. Surface Plane Tolerance
4. Surface Plane Angle
5. Minimum Facet Width
6. Maximum Facet Width
7. Curve Chord Max
I'll appreciate your help, it's for my postgraduate program.
o.alcocer is offline   Reply With Quote
Old   August 4, 2017, 01:58
me3840 is on a distinguished road
Are you meshing with CAD projection? If so, none of these values mean anything as long as your meshing pipeline retains CAD till the meshing operation. They are only used then for visualization purposes.
If you are not meshing with CAD projection or use an operation that does not respect the CAD definition, then these matter.
1-2 affect how the surface is tessellated when curvature occurs
3-4 affect how the surface is tessellated when there's no curvature or little of it
5-6 control the minimum and maximum edge lengths for a triangle
7 I believe controls the maximum size on a curve, but I'm not entirely sure.
me3840 is offline   Reply With Quote
Old   August 8, 2017, 11:01
Hi, it's correct, I'm meshing with cad projection. Thank you for your answer.
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
Parameters rhoSimpleFoam marcus85 OpenFOAM Pre-Processing 0 May 15, 2013 10:36
Turbulence model parameters and equations Maximus91 Main CFD Forum 1 October 24, 2012 14:20
How to get Pro/E Parameters to Show Up Trues CFX 4 September 17, 2012 21:26
Parameters for multigrid solver HaZe OpenFOAM Running, Solving & CFD 3 January 28, 2012 03:05
