Intermittent inlet feed based on pressure/time
Old   July 27, 2017, 21:42
Post Intermittent inlet feed based on pressure/time
Michael
Aeromidd is on a distinguished road
Is it possible to make a mass flow inlet (or any other kind of inlet) something that intermittently opens and shuts off flow based on either local pressure gradients or a timestep?
How might I do that?
I'm trying to see if I can simulate the behaviour of a clapper valve / pulse jet combustion process.
Aeromidd is offline   Reply With Quote
Old   July 28, 2017, 02:36
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Yes. I didn't try it. But we can use Stagnation inlet to define pressure as your inlet condition. If pees sure n region goes above the stagnation inlet then flow should stop. But it may give reverse flow. To avoid reverse flow you can define stagnation inlet pressure as a field function such that it is constant when local pressure is less and it is equal to local pressure when local pressure crosses stagnation boundary condition pressure value. Hope this helps. 😊🤗
Sent from my Redmi Note 3 using CFD Online Forum mobile app
ashokac7 is offline   Reply With Quote
Old   July 28, 2017, 13:24
Michael
Cool, thanks very much! Follow up newbie question... how exactly do I implement that in the field function code? How do I describe pressure at the local region? I can't find anything on the list of functions available that defines local pressure. Or do I have to augment a pressure scalar via the position variable somehow?
Thanks
inlet, intermittent
intermittent inlet condition for channel flow simulation waku2005 OpenFOAM Running, Solving & CFD 1 August 1, 2014 01:14
UDF profile: Fluent method for coupling inlet and outlet I-mech Fluent UDF and Scheme Programming 0 May 10, 2014 11:36
How can I fix a local coordinate system to the inlet phys-zephyr STAR-CCM+ 3 May 8, 2014 06:46
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 08:26
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 15:33
