July 9, 2017, 10:01 |
Interface selection during LES in star ccm+
anas
Hi!
I am trying to do LES from a RANS steady converged solution for Air and is using Fan interface for connecting two regions. The Fan interface works well in RANS steady as well as in transient, but when applied LES model with Smagorinsky Subgrid Scale and all y+ treatment in one of the two regions, then it by default changes the Fan interface to Baffle interface and does not allow to use any other type of interface. But, use of Fan interface is must for me.. so, what should i do now? |
July 10, 2017, 14:02 |
Vincent
Rep Power: 9 |
Hi, could you describe more about your work, that way we might be able to help.
July 23, 2017, 13:43 |
anas
I am simulating a server as porous media and air flow through it. Air aisle is fluid region. I want to carry out LES of air at the exit of Server. I have connected Server (porous region) and Air aisle (Fluid region) through Fan interface. Now applying LES model in Air aisle converts the Porous region of server into Fluid region by default. I want to use RANS in Server region and LES in Air aisle.
Is it possible in Star ccm+ to carry out combined LES and RANS? Is there any other software package in which LES and RANS can be used combined? |
baffle interface, fan interface, les, rans |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Problem In Star CCM Plus | ramarya | STAR-CCM+ | 1 | July 10, 2011 05:59 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
