Virtual Disk Model-Report
Old   July 5, 2017, 07:27
Default Virtual Disk Model-Report
Andrea
afarkas is on a distinguished road
Hi all,
I prepared a simulation based on the tutorial: Body Force Propeller Method: Marine Self-Propulsion, in STAR-CCM+, v11.02. When I want to make a report for a Longitudinal Thrust, Virtual Disk force report was not available in Reports, eventhough in User guide is written:
The following reports are available when the virtual disk model is activated:
•Virtual disk force report
•Virtual disk moment report
•Virtual disk angle report
•Virtual disk rotation rate report
•Virtual disk advance ratio report
Can you help me how to activate this report?
Since, 6DOF Body Force is available in Reports for mine simulation, can I select it and as a Force select an External Forces and Moments: Virtual disk force? If I can use this report, will I obtain a x-component of Thrust force, or magnitude of Thrust (and then I should use cos(abs($TrimDownReport))?
Thanks,
Andrea
afarkas is offline   Reply With Quote
Old   July 6, 2017, 12:56
Matt
fluid23 is on a distinguished road
You should be able to get longitudinal thrust out of the virtual disk thrust report. Not sure why the help files call it something else, it could be a hold over from a previous version that was not updated.
fluid23 is offline   Reply With Quote
Old   July 7, 2017, 06:29
Andrea
Thank you for reply.
I found out that when I create 6DOF, Virtual Disk force report is not available in Reports annymore. But, 6DOF Body Force is available in Reports and then one can select as a Force: an External Forces and Moments: Virtual disk force. I think this corresponds to the Virtual Disk force report.
body force, report, virtual disk model
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Virtual Disk Model - Propeller Performance Curve hlf13 STAR-CCM+ 2 April 23, 2016 08:14
The Virtual Mass Model Deranda STAR-CCM+ 0 February 9, 2016 03:38
Looking for Report "Development and Application of a Zonal DES Turbulence Model CFD" laxwendrofzx9r CFX 4 January 15, 2014 05:03
K - epsilon VS SST turbulence model Maicol Main CFD Forum 0 November 30, 2012 17:25
