CAD body invalid error- Star CCM+
Old   July 4, 2017, 05:19
Default CAD body invalid error- Star CCM+
Paresh
pary07 is on a distinguished road
Hello Everyone,
I am new to CFD and I am in the stage of performing in cylinder CFD simulations for a single cylinder engine. Basically, I have to simulate the flow through the ports. I have extracted the CAD geometry from an existing engine, as in copying all the inner surfaces of the combustion chamber, ports, seat rings, cylinder and the valve guide. I have managed to create a solidified part of it and then I exported a step file (as surfaces) from PTC Creo 2.0 software. Now the problem that I am facing is when I import this step file as a surface mesh and on activating check part's validity and repair invalid bodies, the output shows an error as CAD body is not valid. I maybe doing something wrong that I am not aware of. If anyone could help me, that would be awesome.
Star CCM+ 12.02.011 R8
Thanks in advance
pary07 is offline   Reply With Quote
Old   July 22, 2017, 11:12
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
For exporting from creo try to keep shell and solid both on. Star ccm is going to import surface mesh only. If this doesn't work then don't keep check for parts validity. And then check for errors in surface repair. Let me know if this works.
Sent from my Redmi Note 3 using CFD Online Forum mobile app
ashokac7 is offline   Reply With Quote
Old   July 23, 2017, 08:35
Paresh
Hi Ashok,
Thanks for your reply. I tried exporting as surfaces and as well as solid along with shell option but still , on importing, it shows the cad body invalid error. To explain a bit more, for repairing we have 2 options as in Repair CAD and Repair surface. When I use repair CAD, I get 1 error for self interesting which cannot be repaired automatically. But when i use surface repair, I do not see that self intersecting Error. Any clue why I do not see this error in repair surface. As per this I am just proceeding without having the need to repair. Is this correct ?
Thanks again.
Old   July 25, 2017, 15:42
ashokac7's Avatar
Ashok Chaudhari
Yes you can proceed with intersection error.... Check for error in repair region..
Old   July 27, 2017, 05:17
Paresh
ok, thank you so much.
Old   November 21, 2024, 05:47
Rabin
rpm2000hot is on a distinguished road
Hello
I got this error
when I run turbo design ccm+
I dont how set command prompt setup Arguments.
Incomplete CCM+ parameters or TURBOdesign1 case in invalid state.
rpm2000hot is offline   Reply With Quote
cad error, cad import, port flow, star ccm+
Error in compiling new drag model k.farnagh OpenFOAM Programming & Development 13 May 21, 2016 04:08
Cad Model - Design parameters - Parts and Regions crevoise STAR-CCM+ 1 January 29, 2013 08:52
NeedHuman Body CAD file asal Main CFD Forum 6 January 27, 2013 06:04
CAD kernel error in function PK_PART_receive: Invalid file contents (922) Danielraj STAR-CCM+ 2 July 25, 2011 04:32
STAR-Works : Mainstream CAD with CFD CD adapco Group Marketing Siemens 0 February 13, 2002 13:23
