Francisco
Rep Power: 0 ![]() |
Hi!
I am using a realizable k-epsilon turbulence model with the two-layer all y+ wall treatment in an internal flow geometry that presents sharp angles. I aim for 30< wall y+ <150, but I inevitably get low y+ values in the sharp angles. I am using a polyhedral mesh with 1 layer of prisms, with its thickness fixed at 45% of the base size. I want to conduct a mesh dependence study by changing the base size of the mesh but, if I do so, the wall y+ will change as the prism layer thickness changes. Due to this, a finer mesh might lead to erroneous results if the y+ becomes less adequate for the wall law used. My question is: Is there a recommended practice for conducting the mesh dependence study varying the base size? Should I keep the prism layer thickness constant in all cases so that the y+ remains constant and the number of calculations points in the core of the volume (and not near the walls) is the only variable that changes as I decrease the base size? Thanks in advance! ![]() |
It's harder to control mesh size in star-ccm. You can use controls but they are not full proof. Instead star-ccm can import cas file as volume mesh. So if your geometry is simpler then you can mesh it in hypermesh and then import it in star ccm as .cas
Sent from my Redmi Note 3 using CFD Online Forum mobile app |
mesh independence, prism layer, wall law |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 01:47 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
