Star CCM "cannot load client native libraries..." java error |
June 25, 2017, 09:54 |
Michael Lynch
Hi all,
I am looking for guidance on how to troubleshoot this issue. Star CCM+ installer supposedly installs the program successfully. When I open the program and attempt to open a newsimulation, after putting in my POD key etc. I get the message "cannot load client native libraries..." as seen in first photo. The output window states that the license has been checked out successfully. Software version is 12.02.011 and the license POD key is newly issued. image 1&2 appear after attempting to load a new simulation, pictures 3,4&5 appear after attempting to open the CAD module. I have redownloaded and reinstalled several times with no success. I have tried install older software versions with no success. I have disabled, and then uninstalled anti virus, again with no success. I have updated as well as reinstalling Java also, no success. I have downloaded and installed on a friends laptop and it worked perfectly. Please advise as to how I should proceed in solving this issue? Many thanks, Mike |
December 10, 2017, 05:12 |
Chris
Rep Power: 9 |
I got same problem. did you solved the problem? It would be really nice if you could help me out |
February 12, 2018, 13:18 |
Andreas Giannoulis
Rep Power: 8 |
I got exactly the same problem. Does anyone know how to fix this? Thanks in advance. |
February 13, 2018, 02:12 |
Rep Power: 8 |
Just an idea from my side. Is your java distribution installed correctly?
February 13, 2018, 13:46 |
Andreas Giannoulis
Rep Power: 8 |
I have update everything. I dont think that this is the problem as difference versions of the software works fine. The problem appears only with the version 12.02.010.
Thanks for your help. |
error, install, java, star |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
