Problem Boundary conditions for atmospheric simulation |
Miguel
Rep Power: 9 ![]() |
Hi all,
I am trying to simulate a atmospheric flow. My volume domain is 1500m x 1500m and a height of 1000m. On one side I have a velocity inlet, and on the other end I want to have a pressure outlet conditions. I am using ideal gas model and segregated flow temperature. I know how pressure varies with height and temperature. The problem is in this particular case star ccm+ use piezometric pressure as working pressure, but it calculates using a reference (constant) density. It means that the pressure calculation is wrong at the boundary and because of that I have a vortex on exit. I can create a field function to correct the pressure with constant temperature. However I can't correct it when I use temperature stratification. As anyone face this problem?? Thanks all |
atmospheric flow, pressure correction |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
