May 20, 2017, 15:35 |
CFD plotting problem. Please help!! :(
Hi, I'm having some difficulties with my CFD. As seen in the first picture when the simulation is running the residual is plotting as normal but as for the the other plots Cl, Cd, Cl/Cd etc etc. does just simply do not show any plotting on the graph, if it makes sense to explain it. Please can someone points out what is wrong because I'm just going mad figuring what is wrong. Thanks
May 23, 2017, 04:51 |
Hatim
Rep Power: 9 |
Hello lucbutt,
For your residuals plot, the residuals values are plotted against iterations. But for your Cl, Cd and Cl/Cd plots, the y-values are against "Physical time". It seems to me that you triggered the physical time for the X-axis representation in the "Plots" and "Monitor" nodes. Hope this has been helpful |
VAWT transient cfd problem | ArslanOZCAN | FLUENT | 3 | January 26, 2011 06:25 |
ill-posed CFD problem ? | Noel | Main CFD Forum | 9 | March 28, 2007 11:37 |
CFD problem Setup for Packed Bed Column | Vijay | CFX | 0 | June 20, 2003 08:23 |
What is the Better Way to Do CFD? | John C. Chien | Main CFD Forum | 54 | April 23, 2001 08:10 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
